Sponsored by: CARiD
96 disco how hard to install fuel pump?
Old Feb 25, 2007 | 05:54 PM
lmmnny's Avatar
4th Gear
Default 96 disco how hard to install fuel pump?
96 disco will not start but the engine turn.I need to know how hard to install the fuel pump?How to do it?Thanks
Old Feb 25, 2007 | 09:30 PM
Default RE: 96 disco how hard to install fuel pump?
How do you know it is the pump? have you checked the pressure, how about the fuse and relay/ If it is bad make sure you change the fuel filter also.
The pump is easy to change, just pul up your cargo carpet go thru the access plate to the tank, remove and replace the pump.
Mike
Old Feb 25, 2007 | 10:45 PM
wardolb's Avatar
just be careful not to round off the the nuts on the fuel lines....they have a tendancy to round off
Old Feb 28, 2007 | 08:27 PM
lmmnny's Avatar
4th Gear
Found the problem,just loose connection.Thanks everyone for the help.
Old Mar 4, 2007 | 09:14 AM
tonym's Avatar
changed fuel filter yesterday morn , everything ok until pm when car stopped. no noise from fuel pump [not working] keeps blowing fuse as soon as ign turned on. do i have to drop fuel tank to get to fuel pump ? thanks
Old Mar 4, 2007 | 01:04 PM
Check the fuel pump relay before you go pulling the fuel pump. Also the fuel pump can be accessed thru the cargo floor, under the carpet id a plate to let you pull the pump.
Mike
03discoman
Dec 7, 2016 08:24 AM
Travelor
Sep 24, 2015 06:11 PM
bosshogt
Nov 14, 2011 03:13 PM
JumPeR04
Apr 7, 2011 09:52 PM
dev99disco
Sep 22, 2010 06:15 PM
