Sponsored by: CARiD
96 Disco, missfiring, code P1316c need help!
Old Oct 8, 2012 | 07:48 PM
1996disco's Avatar
8th Gear
Default 96 Disco, missfiring, code P1316c need help!
I have a '96 Disco SD, 4.0L. I am getting a missfire on the 6th cylinder and and random missfire code, P1316. Have replaced spark plugs and wires and nothing changed. Any ideas on what else I can do to solve the problem? Any and all help would be greatly appreciatted!
Thank you
Old Oct 8, 2012 | 08:31 PM
What plug wires did you use?
Have you checked for excessive sludge build up?
Old Oct 9, 2012 | 08:12 PM
1996disco's Avatar
8th Gear
I used the cheapest wires from NAPA
Old Oct 9, 2012 | 08:49 PM
You need to use better plug wires, these things are super picky, I tried using cheap plug wires and had to replace them every 2 weeks.
Magnecore, STI or Kingsbourne plug wires.
Old Oct 10, 2012 | 11:34 AM
1996disco's Avatar
8th Gear
I will try to get better wires and see if that helps. Not even sure if its the wires though, because I have scanned the check engine and one time I got the 3rd cylinder misfirig, after a couple days it was the 6th and now its the 4th one. Also got a random misfire going on.
Old Oct 10, 2012 | 06:42 PM
I used a set of cheap ones and they were bad out of the box, that was before I knew better.
Old Oct 12, 2012 | 08:35 PM
1996disco's Avatar
8th Gear
I just put in $80 dollar bosch wires I got from Napa and no change.
Old Oct 12, 2012 | 09:13 PM
wheelgarage's Avatar
Have you checked the crank sensor and what plugs did you use?
Old Oct 12, 2012 | 09:27 PM
1996disco's Avatar
8th Gear
SUCCESS! It was the spark plugs. Put in BOSCH Platinum Plus 4 plugs.
RUNS LIKE A CHARM
Old Oct 12, 2012 | 09:34 PM
You probably had your spark plugs gapped wrong, you cant gap those snake oil +4's, but its running so go with it.
