97 discovery won't fire
Somebody please help. I'm a Land Rover newbie here bought a 97 for $600 won't start. Mobile mechanic checked it out it has spark, sprayed ether nothing. Turns over won't fire. No check engine light or anything. I swapped ecu from junkyard now I have check engine light on, it sounds like it's trying to fire but just won't catch. It only has 119,000 miles they say it ran a week ago never had an issue. They changed the cooling fan, drove it 100 feet and parked it, now it won't start. Also had no battery in it for a week if that helps. Any suggestions before a pricy tow to a shop
Test the fuel pressure on the fuel rail. There is a schrader valve (like your tires air valve) on the passenger side. You should have ~32-38 PSI with key in position II.
Needing a new fuel pump is a very common repair.
A couple of other items...
Welcome to the board. Always good to have new people. There is a specific D1 section so future threads should be posted there. Also, to prevent having to specify which truck you have every time, it is best to put that info in your signature. Find the 'user CP' section and edit your signature there.
