97 range rover won't start
My 97 will not start, or do anything. When you turn on the key all the electrical comes on but it only makes a clicking noise when you turn it on. It has a new battery and I had the starter tested and it is good. My problem started with my battery draining and causing the int lights and parking lights to come on. It would usually start, but just barely, if overnight. I would try to put in the codes but I replaced the computers a couple yrs ago from someone out in CA and I wouldn't think the originals codes would work. It doesn't show anything on the message but the ususual door open and sunroof. I also had a friend put a tester on it and couldn't get anything to come up, which I'm not sure if all testers work on this car, but he thought maybe the comp is bad since it didn't indicate anything. Has anyone else had this problem?
Mountain State Rover
06-29-2013 02:06 PM
tufftrigger
05-02-2005 02:59 PM
