98 Disco Doesnt want to Kick Over!
Happy New Year Everyone!
Over the last couple days I have not been able to start up my Disco and today it got worse! Previously, My Disco, would just spin, like it was out of gas but it wouldnt ignite, it wouldnt kick over. Today, however that came to an abrupt halt! I gave the battery a jump and as soon as I tried the ignition, the crank started to spin then just unexpected stopped, really hard like! I was shocked because it stopped with so much force, as though something got caught in the system.
The Disco had been working fine but I had to replace the manifold and rocker cover gaskets because it was leaking all over the place. So while i was at it, i decided to take a look at the fuel injectors and fuel rail since I was getting such poor gas mileage. I proceeded to create a DIY 'injector cleaner', nothing fancy, just a rubber hose with a can of carburetor cleaner on one end and alligator clips on the other for power. The injectors cleaned just fine, except for one, which i exchanged for a refurbished injector. Anyway, I didnt have much gas in the tank because im planning on changing the fuel filter, but it had at least 3-4 gallons of gas. Anyway, i gave the car a tune up too and put everything back together.
This is the first time I have had problems at start up and the way the crank just stopped! i figured i must have dropped a screw in the manifold or something so I went to Pep Boys and purchased a OBDII reader but it was a cheapie and didnt give me any problem codes but it did give me the following: MIL Status; OFF, Misfire Monitor; OK, Fuel System Mon; OK, Comp. Component; OK, A/C Refrig Mon; N/A, Oxygen Sens Mon; OK, Oxygen Sens Htr; OK, EGR System; N/A, Catalyst Mon; OK, Htd Catalyst; N/A, EVAP System Mon; INC, Sec Air System; N/A. When the motor was spinning, it simply sounded like it was out of gas. But now it wont even spin.
Thats all the info I have. Does anyone have an idea what happened to my Disco? Thank you in advance.
If there's a solid obstruction in the valve train (e.g. WaltNYC's suggestion) then that would stop things cold.
A solid obstruction anywhere that's supposed to rotate would do the same. Since you just worked on the upper end, it's possible that something fell into a hole somewhere and has locked it up.
doogaloo (01-06-2018)
StormTroopa
05-30-2010 08:28 PM
