Sponsored by: CARiD
2012 Range Rover sport active suspension fault
Old Jan 2, 2018 | 09:50 PM
ruger270's Avatar
4th Gear
Default 2012 Range Rover sport active suspension fault
Hi Guys and gals.
My wife has a 2012 rangie sport with active suspension.
Whats the issue is that to lift the car on a 2 post hoist I have been told that this will damage the suspension unless its locked into access mode.
I dont really understand how extending the suspension could damage the suspension considering that this is a 4wd and does go off road
cheers and hope the new years has been not too hung over
Old Jan 3, 2018 | 04:15 AM
abran's Avatar
Just lift it. No issues.
Old Jan 3, 2018 | 12:24 PM
ruger270's Avatar
4th Gear
yeah I thought it was a bit strange.
the mechanic blamed the suspension fault at the moment on incorrect lifting.
when we ask for access mode the car tries to drop and then goes into extended mode.
Im going to put her on the hoist and see if any air lines are damaged / crushed.
Started to bump steer all over the place recently as well. shockies - im not sure if they aren't stuffed causing the problem.
Im going to get myself a scan tool, do you have one? Got to find one with suspension code access for the rangie. I have noticed that many do not.
Old Jan 5, 2018 | 07:39 PM
abran's Avatar
GAP IID tool, bluetooth version. Luck8 has the best prices. Call Erik and tell him you are a forum member and you want a huge discount.
sounds like an exhaust valve fault.
Old Jan 6, 2018 | 02:00 PM
ruger270's Avatar
4th Gear
Hi Abran, thank you for that.
Sorry who is Luck8?
Im not sure how to contact them.
Many thanks.
Old Jan 6, 2018 | 09:36 PM
abran's Avatar
SOrry, Lucky8.
Search online.
Old Jan 6, 2018 | 09:46 PM
mollusc's Avatar
lucky8llc.com
za105
Sep 16, 2022 10:03 AM
fungolio
Nov 13, 2019 10:17 PM
iceman1120
Aug 1, 2012 08:21 PM
