99 disco still overheating
OK guys I have been having problems with my disco 2 getting hot. I replaced the thermostat a few months ago and had no problems for a solid month. Then a while ago it started to heat up and I let it cool down and checked everything and couldn't find a problem. When I started it up again the problem seemed to go away on its own. I took it to a land rover dealer and they couldn't find any problems. Then today it was driving on the interstate and the car ran fine, when I got off and got in town it started to heat up. So my first thought was that the fan wasn't working. But it is!!! so what could be wrong?
on
RE: 99 disco still overheating
Do you know how to bleed the coolant system, are you having to replace any coolant, got any water noise in the dash, how about the heater does it blow hot at an idle????
Have you checked to make sure your electric fan is working, how about your mechanical, is the hub still good?
OK so update. I took the shroud off and the fan clutch is a little bit loose feeling. The electrical a/c fan is working properly as well. I am thinking about switching over to an electrical fan instead of the clutch.
As far as the water sound in the dash I do have that. I forgot to ask what it was but it has been making me curious. I know that in a vehicle with a regular radiator and cap, you leave the cap off and run the car while it bubbles out the air. Is the bleeding procedure the same for our setup with the cap on the resivior?
on
ORIGINAL: phidelt583
As for bleeding, start with a cold cold engine, remove the bleed screw and with the engine off start adding coolant till you get a steady stream out thru the bleed screw, then reinstall the bleed screw and cap.
Dee Quirod
11-05-2012 03:12 PM
kevinocall
07-13-2012 10:07 AM
