Sponsored by: CARiD
99 Disco Won't Start HELP!!
Old May 23, 2011 | 01:31 PM
RustyHamover's Avatar
Default 99 Disco Won't Start HELP!!
I've got a 99D1 that will not start. A few weeks ago I replaced the fuel pump and it ran fine til the other day. The check eng. light came on soild then went off then the car just stopped & would not crank back up. I checked the pump again it seems fine, But I did check the to see if I was getting anything to the plugs & the fuel injectors And I Was Not. Could it be the relay? Or any other ideas? HELP!! Rusty
Old May 23, 2011 | 07:33 PM
Chris-bob's Avatar
Does the starter turn over or not turn over?
Old May 24, 2011 | 06:34 AM
....... The starter does turn over, Just acts like its not getting fuel to crank up...Rusty
Old May 24, 2011 | 06:40 AM
Oh also I hooked up a Autoxray OBD2 reader to get a fault code and it couldn't read it. Is this a common thing for the code readers not to be able to talk to Land Rovers?
Old May 24, 2011 | 07:38 AM
Possible crank sensor, pretty common issue.
Old May 24, 2011 | 08:53 AM
......I had a guy say it may be the ECU because the Code reader wasn't picking up any signal? But I was thinking if it was the ECU won't that also keep the starter from turning over?
Old May 24, 2011 | 09:13 AM
Any signal or any codes? Crank sensors usually won't throw a code.
If it is the ECU, it is going to turn into a larger can of worms.
Old May 24, 2011 | 09:43 AM
Think the only signal I got from it was it telling me the key was on. And No codes at all. If it is the ECU, I can get a used one for about 150.00 or so. Would a used one work or is there some sort of programing the dealer has to do?
Old May 24, 2011 | 02:07 PM
Chris-bob's Avatar
Have you checked for spark at the plugs?
Old May 24, 2011 | 02:08 PM
Chris-bob's Avatar
Have you checked your fuel pressure?
