Sponsored by: CARiD
ABS and TC light staying on after brake job
Old Sep 12, 2008 | 10:58 AM
DetroitRover's Avatar
Default ABS and TC light staying on after brake job
Just replaced the rear brake pads and had the rotors turned on a 1995 classic. Now the ABS and TC lights stay on.
Could this be an issue with the anti lock brake ring? The ABS sensors seem to be seated properly.
Thank you in advance for your thoughts.
Cheers,
Glenn
Old Sep 12, 2008 | 12:12 PM
Default RE: ABS and TC light staying on after brake job
First of all, you can not turn a set of Rover rotors, they are to thin to start with and the alloy is way too soft.
Go spend the money, find a shop that can read the codes, see what is wrong and fix it.
Don't be surprised if your front brakes start acting up soon.
Mike
MM3846
Oct 10, 2014 11:44 AM
ftby55
Apr 20, 2014 08:44 PM
jdelp
Apr 21, 2009 02:03 PM
luxury1
Dec 31, 2008 07:57 PM
