Sponsored by: CARiD
accelerator/power Problem
Old May 26, 2011 | 02:13 PM
Mchuk22's Avatar
Default accelerator/power Problem
I have a
1998/1999
S reg
Discovery 1
safari
Automatic
2.5 cc
Diesel
When im driving the land rover i will get to a speed im happy with and Bring my foot up untill there is just enough pressure on the pedal to keep the disco at the same speed (Cruising) .
This is when the engine will loose power and a (check Engine) light will come on.
to get the light to go out and get power back all I have to do is press down or release the pedal a bit and every thing is ok.
If you have any advice it would be most appreciated
Old May 26, 2011 | 06:59 PM
You shouldn't need to take your foot completely off the accelerator pedal. Just letting up until you stop gaining speed should be enough.
This sounds like it could be a turbo, intercooler or a dirty air filter.
If it were a fuel problem then it would have less power while trying to speed up not cruise at a steady speed.
Old May 27, 2011 | 01:17 AM
Mchuk22's Avatar
Thank you Spike
I had the air filter changed last month.
What is the best way to find out if the Turbo or intercooler are to blame.
Old May 27, 2011 | 09:32 PM
The intercooler would need to be checked for leaks or a blockage, my Sprinter had a stone go through the intercooler and it had no power at all because of a pin sized leak.
As for the turbo it too would need to be checked out.
I do not know how to check these things other than pulling the air tubing off of the turbo and checking the turbo bearings for excessive wear.
GLOCK3462
Dec 21, 2012 08:01 PM
wyrdvans
Nov 20, 2012 08:36 PM
DiscoSlat
Nov 11, 2012 09:42 PM
Muskrat37
Jun 18, 2012 09:12 PM
charlestonwb
Jul 30, 2011 02:34 PM
