Sponsored by: CARiD
ACE package???????
Old Jan 23, 2007 | 12:13 AM
noemad's Avatar
Default ACE package???????
I havea few questions.
What is ACE package.
I have a lound noise from the ACE pumb area of the motor.
Dose this have anything to do with my saggy Disco.
I would like to replace the air baggs with some spring and shock overhall.
thanks for your advice.
Old Jan 23, 2007 | 11:46 AM
Default RE: ACE package???????
Ace is a set of hydralic rams hooked to each sway bar to keep the truck more level on hard turns, it is not causing the rear suspension to sag.
Describe what ther rear is doing, how many mils on the truck and have you checked to see what is leaking? If you have had the truck for any period of time, you won't like the difference in how it rides with springs.
Mike
Old Jan 24, 2007 | 12:35 AM
noemad's Avatar
the truck has 110 k miles on it.
I've had the truck for one year.
If I hit a bump the truck seims to lower in the back.
If I then cut the truck off after I park the back will drop.
If I let the compresser fenish pumping after I park then the back is ok.
What about the noise I hear. It may be coming from the AC compresser, I'm not sure.
I've test driven a 03 disco v8 that had sping, It felt a little bit smaller however it had a smother ride.
Helpdisco Mike I love my disco II.
Noemad
Old Jan 24, 2007 | 09:39 AM
Send me your tele number and we will talk about your leaking air bags.
Mike
mikeljacobs@comcast.net
MiDisco2
May 28, 2014 08:53 PM
thehrdway
Apr 26, 2011 01:41 PM
tbuckt007
Apr 13, 2010 11:46 AM
alrd
Nov 17, 2006 11:25 AM
00disco
Oct 26, 2005 02:58 PM
