Sponsored by: CARiD
Advice to find part for 1998 LR
Old Jan 30, 2013 | 09:01 AM
R White's Avatar
3rd Gear
Default Advice to find part for 1998 LR
I recently purchased a 1998 Range Rover, which I love.
Unfortunately, I started having trouble when removing the key (an alarm for " ignition key in " would beep, although the key was out). Then suddenly the key became stuck, so I went to a locksmith, who was able to remove it but said I need a new key cylinder.
I called the dealership in Mobile, AL, which advised me the part was discontinued. I have called every parts store in our area, and none of them are able to get the part.
Has anyone else had this problem and found success locating an ignition cylinder? I am not even certain I'm calling this part by the correct name. I should have said earlier that I am a female with zero knowledge or experience when it comes to vehicle repair.
I would deeply appreciate any advice or suggestions. I am a single mom of three, so being without wheels poses major problems for us.
Old Jan 30, 2013 | 09:10 AM
Michael M. Koch's Avatar
Check Ebay. There are a few parts dismantlers (read: junkyards) that specialize in European cars/Land Rovers. Even if they don't have the part you need listed, you can contact them and ask. They might have a truck that still has the cylinder and matching key.
Or try the usual suspects: BPUtah, Rovafarm, Atlantic British, Partsgeek, I'm sure other members will have more ideas. Same thing: If the part isn't listed on their website, try calling them directly.
Old Jan 30, 2013 | 09:11 AM
Another idea: post in the "Parts wanted" section. A few members have trucks they are parting out and will probably be more than happy to help you.
Welcome to the Wacky World of Rovers, Good luck!
Old Jan 30, 2013 | 09:13 AM
R White's Avatar
3rd Gear
Thank you sooooo much! I was unaware of the "usual suspects" you had mentioned. Very helpful!
Old Jan 30, 2013 | 09:43 AM
You're quite welcome! Worst case scenario, there might be an aftermarket part or something from a different vehicle that will work. (Rovers are known for that sort of thing.) Or just take the whole thing out and start it with a screwdriver.
Just kidding
Nguyen
Oct 5, 2012 11:54 AM
camgkh
May 21, 2010 08:24 PM
Disco2Fever
Jul 13, 2009 07:54 PM
indys2k
Nov 13, 2007 08:39 AM
starcraft
Oct 15, 2007 01:42 PM
