Sponsored by: CARiD
Another disco window problem
Old Nov 13, 2008 | 09:21 PM
phidelt583's Avatar
Default Another disco window problem
Hey guys, I need some help.
So I today I was driving and my window went down no problem, then it wouldn't roll up at all. I could hear the motor still running (strong sounding) but the window didn't move. So I took the door panel off to see what was going on, but couldn't see much with the little freaking holes they have. I held the button while "helping" the window go up and still nothing. So I am thinking that the motor is no longer attached to the regulator. So I pushed the window to the top and it stayed.
I was searching for this problem and found a thread where the guy said his motor went too far and pushed the regulator past the teeth. I am going to check this out tomorrow in the daylight, but I am also hoping someone can help me out.
Thanks,
Kurt
Old Nov 14, 2008 | 01:51 PM
DiscoMike2003's Avatar
Default RE: Another disco window problem
If these are the older style sissor style with teeth than that is possible if one of the plastic end pieces/bushings fell off. Help it back on to the motor and it should work but it will happen again if you auto all the way down. Otherwise if its cable and track system on bmws they pop out or break the clip and pop out.
Good luck ask questions,
-Michael-
WC33
May 26, 2015 03:52 PM
caymandrew
May 2, 2013 06:25 PM
Hyakku
Sep 17, 2010 08:49 PM
Jay5oh
Apr 7, 2010 06:50 PM
JAC
Oct 2, 2009 09:41 AM
