Anti-seize vs grease vs Loctite
i know when installing something like ARP head studs they have two torque values listed in the instructions, one with lube and one with out.. One thing i dont like about using arp head studs is the need to re-tourque after X miles.. I'd much rather use good stretch bolts and be done with it.. that last half a turn on any motor i've put together is always scary..
Really I don't want anything to vibrate loose, but I also don't want the threads to seize up for various reasons. I realize the head bolts are a special and sensitive case, but so far I've been using anti-seize on most parts like the trans plug, sump, starter, etc. Seems there's advantages/disadvantages either way.
Love U Landie
02-04-2013 03:17 PM
