Sponsored by: CARiD
Ashcroft axles won't seal after 2 tries. No options.
Old Aug 27, 2023 | 02:38 PM
Broken08's Avatar
Angry Ashcroft axles won't seal after 2 tries. No options.
Hey all, 2004 d2 with 3" lift, ashcroft heavy duty half shafts and cv joints, and lockers. After the lockers ere a few years old I brought them in for a regear and adjustment to the local shop. Axles appeared to be sealed fine before service. They did the diff work and sent it back to me and within a week most of the diff fluid has leaked out of both front axles seals. I returned it, they did it again with genuine seals, and now same result. Leaking out of the axle ends. Now they say they have done everything they know how to do, and good luck. They refunded the repair hours and seal cost, to their credit. But now, I have an unrepairable, undrivable rover. This is considered the place to go for repairs near me.
I know there are a few threads about axle seals not working, but I haven't found a solution. They measured the seals and the flange placement and everything was in spec. Alignment was all correct.
Where do I go from here?
The other Rover repair place said they will do it for $250 an hour but wouldn't guarantee the work. That doesn't sound reasonable.
Old Aug 28, 2023 | 11:40 AM
Harvlr's Avatar
Hey Broken, you should post this question in the Disco 2 section of this forum.
Old Aug 28, 2023 | 12:59 PM
Broken08's Avatar
I did my but I couldn't delete this one
Gnomadf
Aug 17, 2021 07:01 PM
jbullock78
Mar 29, 2019 12:06 PM
MacRoadie
Jun 19, 2018 03:40 PM
KingKoopa
Feb 27, 2017 04:32 PM
R_Lefebvre
Jun 9, 2011 07:30 PM
