Sponsored by: CARiD
Automatic Lockers
Old Jan 27, 2011 | 06:03 AM
Landy@aus's Avatar
Default Automatic Lockers
Can you run Detroit lockers in the front and rear. On Ebay,(billfordsonly) can supply lockers for the front and rear for $525 each. Is this a good price...Any known problems running Dteroits on both axels.
Old Jan 27, 2011 | 07:55 AM
PMKColorado's Avatar
Default lockers
Call Bill at Great Basin Rovers...more info than you could ever digest, sells & installs lockers. Keith at Rovertracks is another great resource. yes, detriot rear and tru-trac front is a popular combo; most LR owners choose to install ARB air lockers. There is quite a bit to consider before buying lockers and depending on your purpose/driving style, simply dropping in Detroits will lead to other required upgrades to consider in HD axels, gear sets, driveline, etc...The cost of lockers is just the beginning...there is a normal progression in upgrading componants to heavy -duty...Check out D-90 source (forum) as well...you can locate complete 3rd members for sale (new & used) with both ARB or Detriot lockers in various gear ratios as well.
FYI: including vehicle info. when posting will return the best info/help
good luck
Old Jan 27, 2011 | 08:20 AM
No Detroits in the front. I run a Detroit in the rear with a front T.T. and it is a great combination.
Old Jan 31, 2011 | 05:13 PM
Landy@aus's Avatar
Default T.t. ?
Hi Mike, is the T. T. in your front the Eaton True Trac?
skatelove303
Jun 20, 2009 08:10 PM
Fivespddisco
Member Group And Special Buys
Mar 1, 2009 06:46 PM
roverwoody
Sep 21, 2008 03:57 PM
andrewmcoffin
Apr 11, 2008 07:33 PM
CrimeScene
Jan 30, 2006 06:12 AM
