Back End Rattle
I am the proud owner of a V8 Discovery. It runs absolutely fine. However, when I go up hill (which is quite difficult to avoid as I live in the Peak District) a sort of rattle from the back end develops. This continues until I reach the top and then for a short while down the other side. The rattle then disappears until I encounter the next hill. Any Ideas????
if its watts, you should be able to hear/see the rattle with someone pushing, like they are trying to tip it over sideways, from the side.
loose/bad shock can usually be heard if you stand inside the cargo area or on bumper and bounce.
there is a video on watts, I think lucky8 video. I have not seen it, but seen it referenced.
good luck
good luck
