BFG KO2 review
My truck was built up when I bought it with good parts but terrible workmanship. Bad bushings everywhere. Two drives shafts practically falling out. Brakes not working. Running like crap. Snapped axle. It was a mess.
I also just bought these tires in a 275/65/18 and the 2'' terrafirma lift (lucky 8) for my 2003 discovery. I just finished installing the lift the other night and will be installing these tires shortly. First need to get the rims powder coated black...
I look forward to trying these tires as they do have a snowflake rating and hope these are a good year round tire for Canada.
Will reply my thoughts once I have them installed.
What size are those?
I am planning to put on a set of the 305/70/16s when they come out - really want to see what a 12.5" KO2 looks like.
Finally got the new tires on and the medium duty 2 inch terra firma lift from lucky 8. Love the tires and lift combo, perfect fit and no rubbing etc... Great tire in the snow but certainly a heavy tire. I wish there was a slightly less heavy duty version of this tire. It only comes in load range "E" for this size witch is overkill for this truck and severely reduces its pickup and fuel economy. Mind you I suspect this is true for most off road tires.
I ended up buying the "rover bones" spare tire relocator before even trying to see if the tire would fit. Don't forget that it's not just space from the bumper you need but also the tire is wider and needs to clear the the back of the door. I will check tonight if I think it would have been possible to fit just by flipping the mount .
Thanks and good point, I hadn't considered that aspect. Still need to address it on mine, running 265/65/18's but haven't replaced my spare yet.
