Sponsored by: CARiD
Bleeding the coolants
Old Sep 19, 2020 | 04:43 PM
dmenchaca1966's Avatar
Default Bleeding the coolants
I put a new water pump flushed out the radiator put a new thermostat and a fan clutch because it was overheating now I put all the fluids in installed everything Now the temperature goes up but when I press the gas it stops and it kind of goes down a little but still there’s a Higher temperature it’s a 97 disco I don’t know do I have a gasket issue or do I still need to bleed the system I don’t know please help
Old Sep 22, 2020 | 08:54 PM
Dave03S's Avatar
It would be really helpful to know which model and year your Rover is.
Old Sep 22, 2020 | 09:58 PM
Default Heating up
1997 Discovery SE7
Old Sep 23, 2020 | 03:07 PM
WaltNYC's Avatar
There are tons of different approaches to bleeding coolant. The basics include...
1. Fill radiator fully and reservoir to just over the fill line
2. Park truck so that passenger front is higher than rear. The more the incline the better.
3. Run truck at 2500 RPM with the heater on full blast.
4. when hot air blows from vents, shut it down and check fluid levels. Add as needed.
5. Take a spin around the block.
6. check fluid level. add as needed.
BTW, best to post in the D1 section. You'll get more eyeballs on your posts.
NVDiscovery
Mar 8, 2020 10:26 PM
acg
Aug 13, 2014 04:55 PM
rovingmad
Sep 10, 2013 09:05 AM
Chaddt
Jun 14, 2013 11:19 PM
DiscoArt
Dec 26, 2009 11:44 PM
