Sponsored by: CARiD
blinker problem
Old May 7, 2007 | 02:36 PM
nuno's Avatar
7th Gear
Default blinker problem
I have a 1996 discovery Land Rover.
Lately the blinkers have been acting strange. Fist they would blink fast. last week they stoped and would remain on but no blinking if i used them...this past weekend they stopped all together.
I checked the fuse and its good.
Any help would be appretiated.
Also one of my headlights seem to be going dim.
Old May 7, 2007 | 07:05 PM
Default RE: blinker problem
Sounds like it is time to replace some light bulbs and clean the sockets getting rid of any old corrision.
Mike
Old May 7, 2007 | 11:04 PM
nuno's Avatar
7th Gear
well...
the hazards do not work. Blinkers do not work.
One rear amber bulb is out on the rear bumper light.
When i activate the alarm all four corner ambers light up normally.
The green signal for the trailer hitch symbol is on and will not go away.
Changing bulbs seems to simple...can it be?>
any help would be appretiated....i need a safe working car for my wife and son to drive in. no blinkers no safe.
Old May 8, 2007 | 11:01 AM
Now with more detail, I agree, changing tail lights would be too simple.
Since your trailor light indicator is on I wouls start with those wires and see if there is a short.
Mike
Old May 8, 2007 | 12:25 PM
nuno's Avatar
7th Gear
location of those trailor wires would help alot.
Old May 8, 2007 | 04:32 PM
Randy Lover's Avatar
may it be the indicator relay box ? it happened on my friends saxo, one time they would work, the next time it wouldnt, i think maybe the control unit
Old May 8, 2007 | 04:55 PM
nuno's Avatar
7th Gear
were is the indicator relax box located. and is it the same as the control unit...which sounds more expensive than the relay unit.
i need to find the relay box....help!
Old May 9, 2007 | 02:03 AM
sorry nuno, i was talking about the same thing, the indicator relay unit, im not sure where it is located but i found some web pages that may help you,
http://www.lrm.co.uk/archive/technical/RossLights.html - this isnt about specific problems with the unit but it might help you find it.
http://en.allexperts.com/q/Land-Rove...er-Problem.htm - this one sounds like the problem you have.
Old May 9, 2007 | 08:18 AM
The trailor wire package is located in the r/r qt. panel. To get to it remove your r/r tail light assembly and look down inside the panel.
Mike
Old May 9, 2007 | 09:24 AM
nuno's Avatar
7th Gear
cann someone give me a link where i can get a blinker relay
