Sponsored by: CARiD
Brakes pedal goes to floor
Old Dec 2, 2022 | 02:19 AM
Robert Tripp Norwood's Avatar
7th Gear
Default Brakes pedal goes to floor
I recently purchased a 1999 discovery 1 and everything was perfect everything was fine. Recently, well today the brakes just stopped working. Of course I went through all the threads here in the forums for this problem but no sauce.
i of course started with bleeding the brakes just to see what happened. I realized that I wasn’t getting any fluid out of either of the rear calipers. The front two were sort of shotty too. I inspected all my brake lines, no fluid on the ground or lines and no hissing sounds.
I thought maybe I’d replace the master cylinder. Did that with no luck. Brake pedal will sort of build pressure then lose it. When I say “sort of” it’s very slight. I do not know what else to do. Even with fluid pissing out of both front calipers I still get little to no pressure on the brake pedal. Should i replace the booster? I don’t understand what’s going on..
if anyone has any information about this please call or text me @ 803-673-4663
Old Dec 2, 2022 | 10:28 AM
Harvlr's Avatar
Robert you should post your technical questions in the Disco 1 section of this forum.
Old Dec 3, 2022 | 09:46 PM
Best4x4's Avatar
Check to make sure your calipers aren't seeping fluid, then you have a F/R Valve. I had a similar issue on a 95 D1 that someone completely gutted the entire brake system trying to figure it out. Turns out the MC was bad all along (the one part the hadn't touched).
Old Dec 28, 2022 | 02:19 AM
adamolan's Avatar
Bill1942
Jun 29, 2021 07:34 AM
RandyH1221GJ
Nov 10, 2019 05:34 PM
deepski@live.com
Jun 26, 2016 06:25 PM
bushpilot
May 10, 2013 02:29 PM
colinski
Jun 15, 2011 06:56 PM
