Brush guard help
Just bought a brush guard...
No mounting hardware.
Does anyone have any good dimensions,pics of the brush guard hardware mounted and unmounted?
Does anyone have EXTRA hardware they might part with?
TIA
Doesn't matter, I will make it, but doesn't hurt to ask.
TIA
If I'm not mistaken, the brush guard attaches to the factory bumper bracket bolts that are already there. Should be two on each side and I believe they have 14mm heads. Just look underneath and follow the frame rails to just behind the bumper and you'll see them.
Yes, you use the bumper bolts, have a friend help you, undo the 4 bolts and remove the front bumper.
Unscrew the little licence plate holder thing.
Put the front bumper back, have friend manhandle the brush guard in place, bolt it back up.
Before you snug the bolts make sure the brush guard is where you want it, you can move it closer or farther from the front of the truck.
smokinwheels
May 25, 2021 11:11 PM
christiansmith6
Jan 7, 2014 07:46 AM
SpeedAgent
Mar 16, 2008 11:06 PM
DiscoMikeandMike
Dec 17, 2007 01:37 PM
