Sponsored by: CARiD
CHANGING TIMING CHAIN
Old Jan 24, 2008 | 08:39 AM
Eulogio's Avatar
Default CHANGING TIMING CHAIN
HOW HARD IS IT CHANGE THE TIMING CHAIN . AND WHATNOTTO DO
Old Jan 24, 2008 | 09:49 AM
Default RE: CHANGING TIMING CHAIN
What year and model, how many miles on it and why do you want to change it?
Old Jan 24, 2008 | 10:21 AM
Eulogio's Avatar
1997 DISCO KNOCKING NOISE IN FRONT OF ENGINE
Old Jan 24, 2008 | 10:23 AM
How many miles???
Have you checked your oil pressure, maybe consider doing a engine flush to free up so oil flow.
Old Jan 24, 2008 | 11:07 AM
Eulogio's Avatar
I GOT IT CHECKED AT A SHOP AND THEY TOLD ME IT WAS THE TIMING CHAIN. EVERYTHING ELSE FINE. IT HAS 133,000. MILES
Old Jan 24, 2008 | 12:26 PM
So, there are 2 things that will show up with a timing chain, timing will bounce around which can be caused by a tired chain or just the little hydralic button that keeps the timing chain tight.
If your timing bouncing around, if not, the hydralic tensioner could be causing the problem and quite often it is because of sludge build up.
Might want to flush out the engine real good and see if that will clear up your problem.
Old Jan 24, 2008 | 02:50 PM
Eulogio's Avatar
THANKS ALOT.DISCO MIKE
Old Jan 24, 2008 | 08:51 PM
sideburns's Avatar
there are no tensioners on the chain,what kind of noise is the motor making?I have worked on thousands of 4.0/4.6 and have never seen a chain issue with these motors...more info please
Old Jan 24, 2008 | 09:02 PM
Eulogio's Avatar
it sounds like if it was a diesl. the noise is a ticking sound
Old Jan 26, 2008 | 10:47 AM
Bartell's Avatar
ORIGINAL: sideburns there are no tensioners on the chain,
Correct.
ORIGINAL: I have worked on thousands of 4.0/4.6 and have never seen a chain
Me either.
However, timing issues used to be quite common through the 80s and early 90s. The timing gear keyways were machined incorrectly for years. As well, the old chains used to stretch. Sure made a lot of money for Cloyes!
ORIGINAL: sideburns what kind of noise is the motor making?
Eulogio: the noise is a ticking sound
Does it fade at all after the engine warms up?
James
