Sponsored by: CARiD
check engine light P0442
Old Nov 22, 2008 | 11:44 AM
phidelt583's Avatar
Default check engine light P0442
OK so my check engine light keeps coming on and throwing the code
P0442 - Evap System Small Leak Detected Fault
I was wondering if there are any common problems to throw this code? I know if the leak is small I will probably never find the problem. Any help is appreciated.
Old Nov 22, 2008 | 11:47 AM
phidelt583's Avatar
Default RE: check engine light P0442
and yes the gas cap is tightened correctly
Old Nov 22, 2008 | 12:07 PM
leaks in the fuel lines to the tank and fual cap can cause this.
Old Aug 21, 2018 | 01:21 PM
T5174's Avatar
You can make a basic homemade smoke tester, you can find" how to"vids on YouTube and I think I paid 30 bucks all together, mainly on a low pressure regulator and some length of rubber hosing. It's best to do it in darkness rather than bright lighting. And you'll need a decent bright flashlight, or uv light depending on which way you choose to go. I used incense and and powerful led flashlight.
update:
I finally got my p0442 code to go away,and to be honest. I'm not sure how, I made sure no smoke was coming from the fuel lines, or tank area. I put the old gas cap that came with the truck back on,and I replaced that damn little 35$ red plastic fitting on top of the intake (I think it's the hard plastic line that comes from the brake booster). Anyway, I know it's not much to go on but one of those 3 things did the trick. Good luck
Old Aug 25, 2018 | 09:55 AM
Best4x4's Avatar
I'd start by replacing the vapor vent solenoid (AIRTEX/WELLS 2N1016) for around $22.00. It's located right by the cruise control pump. To look up the part cross reference it off of a 2000 Chevy 3500 Express Van with the 5.7L V8.
geez another thread from the past.
Old Aug 27, 2018 | 01:24 AM
No Doubt's Avatar
https://www.ebay.com/itm/ACDelco-GM-...QAAOSwud1W~r7K
Take THAT, Jeep!
Sep 4, 2013 06:44 PM
Discovery_Scott
Sep 8, 2012 12:34 PM
wild driver
Jun 7, 2012 09:25 AM
ajordan_0012000
Oct 22, 2008 03:12 PM
