chris44
chris44
Hello everyone, i have just joined this site my name is Chris.
I have bought a Range Rover Vogue 2003 4.4 ltr V8, the problem i have i bought the car cheap as it suspected valve damage.
I took the heads of and had them checked and one needed 4 new valves the other was ok, i have put new head gaskets on and bolts and everything was ok until i started to put water in the system,
i noticed that the water started leaking in to the sump, I noticed that there are two pipes up inside the sump one on either side that look as tho they come from the top of the block, not sure where they go or what they are but this is where the water is coming in from, Can anyone help please. Thank you in advance.
