Sponsored by: CARiD
Coolant issue. I'm lost
Old Nov 26, 2020 | 10:02 PM
Discodummy2's Avatar
3rd Gear
Default Coolant issue. I'm lost
Well guys. I could use some help here. Have a 97 disco 4.0. Had the heads gone thru. New lifters. New gaskets. Only did this because I had an injector fail and bent a valve. Since this. I havent been able to bleed the air out of the coolant. Been over a month trying after work. Days off and whatnot. But I am lost. Runs good. But when she warms up she pushes antifreeze out of the pressure tank. No fluid swapping I can see. I've checked the fresh oil change no antifreeze. Also checked the antifreeze which also is all fresh. Any help is appreciated. About to run it with the thermostat out to see if that helps purge air or whatever my issue is
Old Nov 28, 2020 | 11:26 AM
jimvw57's Avatar
Check the heater hoses. Mine were backwards which kept an air bubble in the heater core.
Gator996
Mar 1, 2017 06:56 AM
Hephaestus
Jan 11, 2016 12:04 AM
discorey
Nov 27, 2014 12:47 AM
OCRover
Aug 13, 2010 05:45 PM
Flyin2jz
Mar 2, 2010 12:54 PM
