Sponsored by: CARiD
Coolant leak at intake
Old Jan 26, 2008 | 12:06 PM
nynole's Avatar
Default Coolant leak at intake
Looks like the deal I got on my new Disco is being overshadowed by my ever increasing list of must fixes. Let me preface this by saying I am new to LR’s and while I am by no means a professional mechanic, I can usually do my own repairs. My 2003 Discovery sprung a leak in the coolant system, where one line from the coolant reservoir and the other from the thermostat(??) meet with the air tube from the air cleaner just under where the throttle cables connect. It’s not leaking from the lines themselves or at the clamps, I don’t know what it is called but it’s where there is a seam under the throttle body. Has anyone experienced this problem before and if so, is it a simple repair? It looks fairly simple but I do not have a repair manual yet and I don’t want to start removing sensors or anything else until I know what they are. Here is a dumb? Should I just take it to the shop. Cannot afford to take it in for every little repair. Thanks
Walt
Old Jan 26, 2008 | 04:30 PM
Default RE: Coolant leak at intake
If you mean the t/body heater unit, there is an up-dated kit to correct that problem at the dealers parts department.
Old Jan 26, 2008 | 05:21 PM
nynole's Avatar
problem is that the nearest dealer is in Jacksonville, 180 miles from Tallahassee. It looks like an O-ring or gasket failure. I thought that I would just replace the seal and pick up the kit next time I'm in Jacksonville or Tampa or try to have it shipped out to me.
Old Jan 26, 2008 | 05:41 PM
Or just connect the 2 hoses with a loop of cooper tubing and do a complete by-pas, I did this 3 years ago with no problems.
Old Jan 26, 2008 | 05:53 PM
nynole's Avatar
You know, the thought did cross my mind but I wanted to err on the side of caution. I mean it's that way for a reason, right? But if I can bypass with no problems, then I might do that. Here is another silly ?. What is the advantage of having the throttle body heated?
Old Jan 27, 2008 | 10:34 AM
nynole's Avatar
Update: Throttle body heater bypassed with copper tubing, cost $2 for the tube, a brisk motorcycle ride to Lowes, and less than an hour to complete the job. Thanks for the suggestion.
walt
Old Jan 27, 2008 | 11:22 AM
Well the go end of it was you got to get out on your motorcycle for a ride today.
Don't worry about any side effects. I do many near 0 degree cold start and have never had a problem.
Old Nov 30, 2008 | 07:59 AM
tigerpaws's Avatar
Hi, we had the intake manifold gaskets replaced due to gross leakage. After getting the D2 back, we noticed a coolant leak on top of the drivers side valve cover. We ordered new coolant lines for the throttle body heater. Replaced same but still have a small leak.
We presumed that the heater device itself, the item with two tubes coming out of it, has no seals. But this thread seems to suggest otherwise. Is there a gasket between the throttle body and the heater body?
thx
Ant
Old Nov 30, 2008 | 10:00 AM
You have 2 choices, by pass the 2 hoses with a small piece of copper tubing or order the replacement kit from Rover and reseal the unit.
Old Nov 30, 2008 | 06:58 PM
tigerpaws's Avatar
thx Disco Mike,
Since we run in cold weather, we've ordered the kit from Atlantic British ...
cheers,
Ant
