Sponsored by: CARiD
Cooling system pressure leak?
Old May 30, 2008 | 05:56 PM
dsmtrain's Avatar
8th Gear
Default Cooling system pressure leak?
I just purchased a 2000 Discovery and have noticed air/pressure coming from the radiator reservoir cap when the engine is hot. I do not seem to be loosing fluid (just noticed the noise a couple of days ago) and the engine doesn't over heat - is this normal? The used car lot I bought it from says it is but they are not a Land Rover dealer.
Thanks for your help.
Old Jun 1, 2008 | 08:46 AM
Default RE: Cooling system pressure leak?
It would be a good idea to replace the cap, just to make sure there is no problem.
If it continues then a coolant pressure test might be called for.
Let us know how it turns out.
Old Jun 1, 2008 | 03:37 PM
dsmtrain's Avatar
8th Gear
Thanks Disco Mike, you were right on. I replaced the cap and have been driving it for two days with out any problems. I really appreciate the help - the dealer had me scared with their suggested head gasket replacement!
pacorulez
Jul 15, 2011 08:39 AM
FightOnUSC79
Jan 13, 2011 02:17 PM
mwindth
Jan 7, 2010 11:15 AM
Dino76
Jul 3, 2009 09:20 AM
jkeving
Apr 11, 2007 11:27 PM
