Sponsored by: CARiD
Crazy Radio/Transmission Error
Old Apr 10, 2019 | 01:59 PM
LR3GoneWrong's Avatar
Default Crazy Radio/Transmission Error
I’m getting the Limited Gears Availsble warning, cannot shift out of park - I located the manual release and there are no noticeable problems with the transmission.
Tested the alternator and battery, everything is working fine.
Changed the Stoplight Switch, and the problem went away for an hour.
Reset the computer, then the radio went crazy and was all static on every mode.
Then it ran fine for an entire day, but now the limited gears available is back and the radio says “CD error, please eject.”
2008 LR3 HS V8.
Im starting to wonder if the ECU is bad.
Any ideas?
2008 LR2 Owner
LR2
18
Mar 26, 2022 07:10 PM
geoffthepoolguy
Sep 20, 2010 04:03 PM
jmang
Dec 11, 2006 01:51 PM
amnesia622
Jan 5, 2006 08:11 PM
alimac
May 5, 2005 03:46 AM
