Sponsored by: CARiD
D2 Running Rough + Radio interference + Replaced Wires,Plugs
Old Jun 10, 2016 | 02:18 AM
samroy92's Avatar
Default D2 Running Rough + Radio interference + Replaced Wires,Plugs
I've been in a thread with Charlie_V on this issue [new member introduction] and am trying to reach out for more advice.
This Disco has been running rough and threw misfire on Cylinder #5 code. If the car is idling in park and I press the gas pedal it has a faint shuddering. Once it stops accelerating and reaches a constant RPM the shuddering stops. When the car is moving and the engine is under load this becomes more apparent.
I decided to take a look under the hood and make sure the plug was still decent on Cyl #5, after tinkering around with the wire I noticed this radio issue:
So I replaced all the plugs and wires with Bosch +4's, and Magnecor 8mm wires from RoverParts. WHAT A PAIN IN THE ***. Still the same issue however, rough idle, rough acceleration, and now radio is going crazy. Now I get the occasional Cyl #7 code being thrown as well.
Here are the current diagnostic codes it's throwing:
turf63
Audio/Visual Electronics
Jan 9, 2012 07:36 PM
tommytwotone
Oct 4, 2009 11:14 AM
Gavster
Jun 17, 2009 08:50 AM
mussells
Defender
Nov 23, 2006 10:46 AM
