D90 nas
D90 nas
Hey everybody. I have a D90 5spd with the 3.9 and just recently it has started to shake/vibrate when accelerating at speeds of 30+ mph. If you push the clutch in or let off the throttle at speed it stops. If you just rev the engine there are no vibrations. The computer does not have any codes and all the fluids appear fine. I've also climbed under and checked the drive shafts for play and do not see any funny tire wear or missing wheel weights.
Does anybody have any suggestions? I'm stumped. Thanks
Obvious thing to look at is drive shafts, but if they're ok... Does it only happen in one gear? is it only speed dependant, not 3rd gear at 30mph, and 4th at 45mph(or however the speeds work out).
But speed dependant, which it sounds like it is, you're looking t-case to wheels - drive shafts, diffs, cv joints(if you want to call them that).
sbuige
02-24-2008 08:57 PM
