Sponsored by: CARiD
Disappearing Oil
Old Mar 19, 2008 | 04:59 PM
Archimedes's Avatar
5th Gear
Default Disappearing Oil
Purchased my 04 DII with about 18K on it last July. Been changing the oil regularly, but twice (in the last 10K or so miles), the oil light blinks (once or twice), then goes off. Upon checking it, there is no oil showing on the stick ~ 4 qts low! She's not smoking;no leaks when parked; no visible oil or burnt oil residue on intake, heads, etc.Any thoughts?
Old Mar 19, 2008 | 05:19 PM
Default RE: Disappearing Oil
Intake gasket between trhe top and bottom intake manifold.
You better start checking it on a regular basis.
Is it still under warranty, if so have them start up a work order and let them check it on a regular basis.
Old Mar 19, 2008 | 06:06 PM
WolfPack's Avatar
Wow...an intake gasket at 18k miles?! Pretty wild..
Old Mar 19, 2008 | 07:45 PM
As a service manager, I have seen brand new vehicle have to be pull off a transport a our dealership cause the engine or tranny failed before it hit the lot, so why not a gasket?
Old Mar 19, 2008 | 07:51 PM
WolfPack's Avatar
Wow...I guess anything could fail you're right. Production tolerances can get ya!
Old Mar 19, 2008 | 09:55 PM
socalrover84's Avatar
intake gasket leaking oil? you mean the intake gasket leaking oil out of the valley? make sure your not leaking oil for sure add dye to your system and check it.
Old Mar 24, 2008 | 07:57 AM
Archimedes's Avatar
5th Gear
Thanks for the input fellas'. Not sure what you mean socal....I'm rather inept when it comes to this stuff. I've NEVER seen any oil spots on the ground (park in the same places), and as far as I can determine, I don't see where oil has been bowing onto the intake or head and burning-off. I was gonna take it to Tyson's Land Rover (VA) as it's still under warranty (~35k now), but I was thinking I'd first take it to an independent rover shop and get their take so I have some idea BEFORE I go. I'll keep you guys updated.
Old Mar 24, 2008 | 10:03 AM
Back to my original thought, are you in warranty, if so go in and let them set you up with an oil consumption program where they will track it if necessary.
Old Mar 24, 2008 | 02:00 PM
Archimedes's Avatar
5th Gear
ORIGINAL: Disco Mike
Yeah Mike , still covered by the original LR warranty! "Oil consumption program" eh, I'll mention that when I take it. Guess they"ll let me know the reason BEFORE the warranty runs out, right ? Thanks again!
Old Apr 2, 2008 | 09:26 PM
landrover1502's Avatar
normal oil consumption is 1000-1500k miles per quart, check the dipstick and do the math
