Sponsored by: CARiD
Disco 2-2001 Front drive shaft fell out, cracked transmission housing.
Old Apr 2, 2013 | 03:09 AM
MLX665GP's Avatar
6th Gear
Smile Thank you for all the advice
Thank guys for all the advice. I will drill a 1mm hole at the top of the crack to stop this progressing and then clean and grind out the crack area and apply some sort of aluminium repair material to the crack. I am in South Africa so am not familiar with JB Weld. What should be inserted into the newly drilled hole. As this area is not under pressure could I insert a bit of aluminium epoxy putty.
Old Apr 2, 2013 | 07:29 AM
drowssap's Avatar
yes, the idea of the hole is it will keep the crack from continueing to spread but you will want to fill the hole with whatever you use on the crack and file it smooth.
Old Apr 9, 2013 | 09:44 AM
Rodsram's Avatar
MLX665 GP,
JB Weld is similar to some of the Pratley products, eg you could use Pratley Steel.
MLX665GP
Oct 1, 2015 03:40 AM
PanamaDisco
May 22, 2014 07:48 AM
Chrisinhouston
Oct 30, 2013 09:40 AM
TripleThreat
Apr 12, 2011 08:58 AM
wess98range
Mar 5, 2009 11:04 AM
