Sponsored by: CARiD
disco 2 blower moter
Old Oct 26, 2013 | 06:54 PM
stevekep's Avatar
Default disco 2 blower moter
I have an 03 disco 2 blower motor won't work has power and works when jumped
Old Oct 26, 2013 | 10:00 PM
TRIARII's Avatar
Are you referring to the heater blower motor? What condition is the battery in? Does the Disco start up and run fine? I ask because you mentioned something about jumping.
Anyways if while the vehicle is turned on and the heater/a/c blower motor does not work then either the motor itself has died or a loose connection OR the heater fan assembly is clogged with a bunch of random **** and needs to be cleaned out. I would suggest take out the heater blower motor fan assembly and cleaning it out, then reinstall and see if it works for you. I dont know if any fuses are linked but you might also want to check your fuses to see if any are bad. The owners manual has a diagram of the fuses and their functions.
If your motor ends up being bad then you can settle with a cheap used motor blower assembly. Several members on this forum salvage good used parts from Land Rovers and will offer you very reasonable prices. You can also check out roverlandparts.com they are a company that specializes in the sale of used Land Rover parts.
Old Oct 27, 2013 | 01:50 AM
jafir's Avatar
Look for a burned connector maybe:
Disco 2 blower dead - Land Rover Forums : Land Rover and Range Rover Forum
cornbreadj
Feb 27, 2014 09:45 PM
MontanaPete
Nov 25, 2008 11:00 PM
jrparks
Nov 9, 2007 02:39 PM
willdisco99
Jul 9, 2006 12:59 PM
eric2
May 28, 2005 02:44 AM
