Disco 2 turns over, but doesn't start
HI there. New to your forum and need help.
2000 Discovery 2 ran perfect last night. This morning, wife went to start, hazard lights came on, car turned over fine with plenty of energy, but has not started in 15-20 attempts. Can not turn hazards off, kind of strange.
Please share cure for starting car if known. THANKS!!!
The security system sometimes flakes out. Try locking and then unlocking the vehicle with the remote first. Then try to start it. If no-go, then from the outside try locking and then unlocking the vehicle with the key. And then try to start it.
Regards,
Geoman
www.eurotekapg.com
Regards,
Geoman
www.eurotekapg.com
on
ORIGINAL: geoman
Regards,
Geoman
www.eurotekapg.com
Regards,
Geoman
www.eurotekapg.com
Mike
Thanks Mike and Geoman!!
Unfortunately the lock thing did not work out.
However, re-tracing my steps the last 24 hours, I did fill the tank yesterday morning.
I was able to put 22.5 gallons in it with a capacity of 25 gallons. Normally, I can only put 18-20 gallons in it.
Perhaps letting it get that low allowed sediment to clog filter or injectors?
Does this sound reasonable? If so, what is my next step?
Thanks so much!!
Kevin
Thanks so much!!
Kevin
Well, your Disco II does not have a external fuel filter-- only a "sock" filter on the fuel pump which is immersed in the fuel tank.
You are saying that the engine cranks over just fine, but does not even make any attempt at starting? Have the wife turn the key to the on position (not all the way to the start position) while you listen at the fuel tank in back. You should hear a "whine" from the electric pump for a few seconds---until it builds pressure. If no noise--- then possibly you lost the fuel pump.
regards,
Geoman
regards,
Geoman
