Sponsored by: CARiD
Disco 2 Wiper Motor Replacement
Old Mar 30, 2016 | 11:05 AM
dead_battery's Avatar
Unhappy Disco 2 Wiper Motor Replacement
Hey guys,
Ive searched but couldn't find anything, Im looking for instructions to replace driver side wiper motor, with rust the tip of the motor spindle/shaft snapped so the nut cannot thread back on securing the arm, see photo, anyone have or know how to replace the motor?
Discovery II - 2004 TD5
Thanks!
Old Mar 30, 2016 | 11:13 AM
Racer X's Avatar
Remove that big nut on both sides, then remove the cowl on both sides, and then remove and replace the wiper motor. You'll see it when you pull the plastic cowling off.
Be careful not to break the cowling, it's old and brittle at this juncture.
Old Mar 30, 2016 | 11:14 AM
Thanks so much Racer X!
Old Mar 30, 2016 | 12:12 PM
acamato's Avatar
You may want to look at replacing the whole wiper/linkage assembly. It will be easier and most likely cheaper.
Old Mar 30, 2016 | 02:00 PM
Racer X's Avatar
You're right, I read right past that.
@dead_battery, keep the motor you have, you'll want to replace the wiper linkage assembly.
Old Mar 31, 2016 | 04:29 AM
Thanks so much, I was hoping it would be possible to replace the broken part rather than the motor
Old Mar 31, 2016 | 04:30 AM
Im on it! Thanks for the reply
Old Mar 31, 2016 | 04:35 AM
Guys, i just called a 4x4 salvage yard and they said I need to replace everything including the motors? Surely this isn't correct?
Old Mar 31, 2016 | 07:30 AM
acamato's Avatar
I agree that you can't replace just the broken part. The part appears to be pressed into the linkage. Even if you could replace just the broken part, you need to pull the assembly anyway. It would be easier to replace the assembly.
Heres google search for photos: https://www.google.com/search?q=DKD1...=1920&bih=1031
Paul Grant has one listed on eBay for $40 shipped. http://www.ebay.com/itm/Land-Rover-D...tWLp~N&vxp=mtr
Old Mar 31, 2016 | 07:40 AM
I agree that you can replace just the broken part. The part appears to be pressed into the linkage. Even if you could replace just the broken part, you need to pull the assembly anyway. It would be easier to replace the assembly.
Paul Grant has one listed on eBay for $40 shipped. Land Rover Discovery Series 2 Windshield Wiper Motor Assembly DKD100630 | eBay
thanks so much! as I'm in ireland I may have a look in salvage yards here before I jump on eBay, thanks of the links!
