Sponsored by: CARiD
Disco 2 won't shift out of first when hot.
Old Oct 3, 2015 | 11:17 PM
guevara42's Avatar
5th Gear
Default Disco 2 won't shift out of first when hot.
Hello fellas, My 01 Disco 2 will not shift out of first gear when the transmission gets to temp. I noticed this a few months back. It drives fine when it's cold, but when I drive it for 20 min or so and park it for a couple of minutes then turn it back on and drive away, it will not come out of first gear. I have to let it cool down a bit before it drives normal again. Transmission has fluid. Radiator is only 8 months old. Any suggestions would be greatly appreciated. Thank you.
Old Oct 4, 2015 | 07:42 AM
dusty1's Avatar
1st. Check fluid level and condition. You want it to be red not burnt and you also want to check / fill it while it's running, you can also tell if it's pumping .
likely going to be low fluid level or dirty clogged filter / not pumping
Old Oct 4, 2015 | 10:22 AM
guevara42's Avatar
5th Gear
The fluid and filter where changed about 3 months ago and it's pumping normally. Disconnected hose and it has strong flow.
Old Oct 12, 2015 | 08:46 PM
chubbs878's Avatar
Go to Ashcroft Transmission to the FAQ and I think there is a topic on this. If it does not jive with your application then you can send him an email and he will reply with your answers. I would include all applicable info as discussed here
Old Oct 12, 2015 | 09:06 PM
guevara42's Avatar
5th Gear
Thank you. Will do.
bigred2929
Aug 6, 2015 10:00 PM
bigred2929
Aug 6, 2015 09:58 PM
riggskwong41
Dec 4, 2014 10:59 PM
challishodge
Aug 7, 2010 11:06 AM
Cirrus
Jul 27, 2005 10:51 PM
