Sponsored by: CARiD
DISCO 97 CRAK NOISE
Old Dec 24, 2004 | 07:26 PM
yogi's Avatar
6th Gear
Default DISCO 97 CRAK NOISE
I start to have a crak noise under the car posible drive shaft ?,the noise is when I start from full stop,any advise ?
Old Dec 25, 2004 | 07:07 PM
Takeo's Avatar
Default RE: DISCO 97 CRAK NOISE
Hi !
That sound may indicate a badly worn universal joint in one of the driveshafts. Put trans in neutral, get under vehicle and check driveshafts for UJ play.
I may also have another cause: gearbox, radius arm bushes, rear triangle ball joint play... One (unsafe) method of trying to find out is lift truck up on an elevator with all wheels free. One person stands under truck to listen/look, other "drives off".
I had a loud drive-off clang once, in my old series3. Could not find it until a kid in the back found that my jack was not properly lashed down...
Regards,
Takeo.
http://www.landroverclub.net
Old Dec 26, 2004 | 03:24 PM
yogi's Avatar
6th Gear
ok I check the drive shaft with the car in neutral and no movement ,when I engage the diferential the noise disappear for one day[X(]
david4ducati
Mar 1, 2015 07:59 PM
30more
May 28, 2012 05:01 PM
Robbo
Jun 15, 2005 05:03 AM
adrianwood
Freelander
Jun 13, 2005 08:53 PM
