Disco II coolant leak, driver side, bottom engine, near Crank Position Sensor
2004 Disco II, 106,000 miles
Have not seen this anywhere so posting here for your wisdom . . . .
Have a coolant leak from what seems to be an engine seam just below the exhaust manifold on the driver side of the engine.
Coolant bleeds out while running and slower while off. Coolant has leaked onto crank position sensor cuasing it to stop while running . . . have to wait about 20 minutes to restart after this happens.
No leaks from above this point (checked throttle body . . . no leaks there). Is this a seam from when they molded the engine?? Any ideas on how to fix this?? JB Weld??
richardfeynman
Oct 27, 2013 08:16 AM
JHDisco2
Nov 3, 2009 07:06 PM
