Sponsored by: CARiD
Disco II - Rear Suspension Level Warning Lights
Old Feb 28, 2013 | 06:43 AM
Four Engines and Counting's Avatar
Default Disco II - Rear Suspension Level Warning Lights
We replaced the extortionately price air shocks (after blowing the original and a replacement set in quick succession) with the coil spring conversion a long time ago. The instrument panel rear height adjust (bottom left) warning light is on all the time and the one next to it comes on intermittently.
What's the best way to disconnect / short these circuits so the warning lights don't show up? Should I just remove the offending bulbs from behind the instrument panel?
Thanks.
Old Feb 28, 2013 | 06:48 AM
You will need to have a mechanic, with the proper scanner go into the computer and shut of the SLS.
Old Feb 28, 2013 | 08:17 AM
Thanks but I think I prefer just pulling the bulbs out. There's got to be a simpler (cheaper) way of doing it than that...
Old Feb 28, 2013 | 09:48 AM
Racer X's Avatar
You must be new here.
The only way to disable the SLS system is via scanner to reconfigure the SLABS and BCU. No one is recommending you go out and buy one, but you will need someone with the proper scanner to make the change. Also, until you disable the SLS system via reflash, unplug your compressor. Unless you like waking up to a dead battery every morning.
cipher982
Nov 9, 2019 11:22 AM
superkev
Oct 10, 2014 04:57 PM
thehun
Jan 28, 2011 09:03 AM
Manicoti
Jan 23, 2011 09:22 AM
EstorilM
Oct 20, 2010 09:40 AM
