Sponsored by: CARiD
discovery cutting out help!
Old May 1, 2008 | 12:01 PM
john1doherty123's Avatar
4th Gear
Default discovery cutting out help!
help my 99 disco has just started cutting out i was driving along when the engine management light(check engine light i think) came on a few seconds after this the car lost power and drove slowly for about 1 min them the engine cut out completly! when i turned it off and back on again it drove for about 2 miles before happening again, turning it off and on again it drove all the way home no bother. it has since happened a few times and today 4 times, the car just stops dead no power. can anyone give me a reason for this please
john
Old May 1, 2008 | 03:19 PM
Default RE: discovery cutting out help!
Go get your codes read and get back to us with your exact 4 digit fault code numbers.
How many miles on the truck and when was it tuned last?
Old May 1, 2008 | 06:24 PM
4th Gear
mike
there is just over 100,000 on the clock and its the td5 2.5 td as to when it was last tuned who knows i have had it a year and had no problems with it till now. i have a problem with diesel leaking where it enters the engine (i am not too familiar with the tec speak) large block at the back of the engine but cant get to where it is leaking. could air be getting into the fuel line and making the engine cut out? i can manage when it does stop (hazzard lights and a smile to other drivers) but the wife panicks and phones me. as for getting the codes read i will try to get to a dealer as thereare not too many local garages here in little old ireland that will read the faults for me the lift pump is working fine but i will try changing the fuel filter tomorro as it is in nearly a year
cheers john
Old May 1, 2008 | 07:19 PM
Sorry,
It didn't mention it was a diesel and I have no experience with them.
Let us know what you find.
Old May 15, 2008 | 05:00 PM
4th Gear
just in case anyone else has the same trouble with a diesel disco cutting out i have cured it. turns out that when i used an injector cleaning additive the deposits that were cleaned out went to the fuel filter (behind the rear drivers side wheel) and caused the filter to become clogged up making the fuel stop suddenly for a second thus cutting out the engine!
simple cure changed the filter and away we went. cheers!!!!!!!!!!!!
Old May 15, 2008 | 07:10 PM
Pretty normal thing to happen when clean the fuel system.
ooh1
May 19, 2013 04:38 PM
A Team
Nov 13, 2007 08:45 AM
ChrisW6
Sep 29, 2007 12:26 PM
westernsun
May 27, 2006 04:24 PM
landrover
May 14, 2006 12:20 PM
