Sponsored by: CARiD
Discovery starting problem after runnung out of gas.
Old Dec 4, 2006 | 09:13 PM
cobralootman's Avatar
3rd Gear
Default Discovery starting problem after runnung out of gas.
1997 Disco wont start after running out of gas on a decline (hill). Not sure what the deal is, but it just turns over forever without catching. Is there a reset or something i need to do to prime it somehow? I pushed the fuel shut off reset. not working. should i use starter fluid to try to get it running>? I hvae no clue. its not showing any computer codes either...
cobralootman@yahoo.com
Thanks
Brian
Old Dec 5, 2006 | 02:31 AM
indynotch50's Avatar
4th Gear
Default RE: Discovery starting problem after runnung out of gas.
I would not use any type of starting fluid. Trace the fuel line, I would start at the engine. You will want to start at the fuel rail over top of the injectors. Trace the line back and see if there is a fitting in the line you can unscrew, this will at least let you know if you are getting fuel to the engine. If no fuel there, then keep tracing back, checking everywhere you can...
Old Dec 5, 2006 | 02:38 AM
3rd Gear
right on, thank u . i will try all that in the morn... Im ok with carburated cars, but when its gets computerized, common sense doesnt work any more.
Brian
roverguy00
Aug 4, 2012 02:43 AM
Kandow
Nov 2, 2011 07:39 AM
omarmest
May 5, 2011 09:30 PM
bowser881
Dec 17, 2009 01:19 PM
AKRover
Jan 1, 2009 04:39 PM
