Sponsored by: CARiD
Doors wont stay locked
Old Oct 26, 2010 | 10:32 PM
Disco__Stu's Avatar
Default Doors wont stay locked
I just purchased a '97 Disco and when I go to lock my doors they will unlock themselves right away. I've tried by locking the driver door and closing it and also by using the key while all doors are closed. Any tips? Thanks in advance
Old Jun 17, 2014 | 08:28 PM
iddis's Avatar
I'm having the same issue with mine…have you found a solution by chance?
Old Jun 18, 2014 | 09:36 AM
96 rover's Avatar
Check to make sure all of the doors are closed if the alarm system picks up any kind of signal that the door is open the locks will automatically unlock. I had the same issue with mine I got some non conductive spray/lube and sprayed the door lock and lubed it and it seemed to work. The locks in the rovers are full electric and if the switch is not made the doors will not lock.
wynhd
Aug 28, 2012 11:33 PM
rcg'sdisco
Aug 29, 2011 08:12 AM
LockedOut
Jan 14, 2008 11:40 AM
Jazzonthelow
Jul 1, 2007 11:23 AM
auburndmbfan
Aug 26, 2005 12:48 AM
