Sponsored by: CARiD
Driver's power window mystery
Old Aug 5, 2017 | 12:36 PM
mattaebersold's Avatar
3rd Gear
Default Driver's power window mystery
Hey guys, been dealing with the driver's power window ever since I got the truck a couple years ago. Finally had enough, and I want to continue the diagnosis and try and determine the cause.
My gut: Th BCU, since the horn doesn't work either and they both route through there.
Here's what I know is fine:
- driver's window regulator
- window motor
- the wires going through the boot cover in the door hinge area
- the switch itself (I swapped with the passenger one, and same problem)
My suspicion is that it's somewhere upstream of the door itself, and upstream of the switch itself. All of the wires 'upstream' go into the BCU, so that's why I'm suspecting this.
Here's the symptoms:
- driver's power window doesn't work at all
- all other windows work great
- horn doesn't work (wheel switches seem fine... related?)
- you can hear the clicking sound as if something is trying to actuate on the window switch, but only when trying to roll it UP. When you click down, there's no sound... completely dead.
- all other window switches you can hear a 'click' on both up and down.
Motor? I suspected that, and I had a new 'used' motor shipped. I had the motor out of the car, and still plugged into the wire harness. I then tried the switch to see if the motor would spin it's little gear, but nothing, on either the motor that was in there or the new motor I got. Either both are duds (unlikely) or there's another problem.
The ultimate reason I'm suspecting the BCU is because the horn doesn't work and it's also routed through it, and the fact that I'm hearing it try to click when pressing up, but nothing when I'm pressing down. This leads me to believe it's an electrical gremlin, rather than something mechanical.
Is there something I'm missing? A relay/fuse? Are there any other tests I can do to rule out other problems? I really hope it's not BCU, cause those things I hear are v. expensive and need to be keyed to the car specifically.
Old Aug 5, 2017 | 02:05 PM
aemnky606's Avatar
What year model do you have?
Old Aug 6, 2017 | 11:29 AM
3rd Gear
Oh my gosh im sorry I didnt say... 2000 Discovery V8
collector87
Oct 13, 2012 12:11 PM
djmitten
Aug 12, 2011 05:12 PM
bigfun
Mar 14, 2008 09:27 PM
chrisusvi
Nov 6, 2007 08:59 AM
Str8BacardiL
Mar 18, 2006 10:57 AM
