e brake will not catch
so i had my console removed, yesterday. I removed the cable from the hand brake, in doing so. I guess I hyper-extended it or something stupid, because after reassembly it does not work right. It does not have tension on the holding gear. so it does not make the rapid click and catch on the up motion. I can give it a stout slap and the release button will pop out as it should. I can then pull it up and it makes no gear clicking sound but will sometimes catch and hold. I push the release button and again the button will not pop out unless I slap it around.
Did I miss something? is there a spring that I do not know about? I do see that while extended with the cable off, the gear catch can swivel to the wrong position. I checked about 15000 times and that is not the case. any ideas?
thanks
thanks
