Engine chirp almost all the time
My engine chirps when starting, accelerating, pretty much always. It sounds like it's coming from the very top (toward the back) on the intake manifold.
Has anyone had something like this happen? Any ideas on where to start?
Here's a video of it happening:
https://youtu.be/oMAFAuESFEw
If it isn't an automatic, I'm an idiot. If it is that a possibility. Nothing else at the back chirps. You'll know if you gun the engine in drive and you hear a loud clang then lose forward motion. Ask me how I know.
The sound turned into something far worse after driving it a bit more. It almost sounds like the exhaust is completely open on one of the cylinders, but that's not the case. It's coming from the driver side toward the back of the engine (under the throttle body).
https://www.youtube.com/watch?v=xa1aFCZ5A8M
Okay. That's a head gasket blown,. 100 percent. It is blown in the valley. I thought I heard a click before but that's exhaust sound. That's the Choo Choo sound people talk about. I've bought a rover in that exact condition (but Disco II).
I'm positive.
The good news is that youd rather rather have an exhaust leak than a water leak. But either way that is a head gasket job. I guess it is possible that it is a leak from the exhaust/valley gasket but it sounds just like the two I have experienced.
I just looked for a picture and can't find it. In both instances I had about a 1/4 inch piece of the head gasket missing. The composite material blows and then the heat and pressure works a section of the metal ring out. Eventually the leak gets bigger.
Please do get a second opinion but I'm pretty darned sure.
