Engine Oil Light
Engine Oil Light
Ok here is my question my wife was camping up north with the kids and her friends on there way home on the freeway the oil light came on so she pulled over and as soon as the truck stoped she said it just stalled before she could shut it off.First thing i did was check the oil (i know it was full because i checked it before they left) but it was full only bad thing was it was blacker then black. i'm just Hoping the motor isn't dead i had it towed home because i don't want to try and start it since i did have her try and click it over when it was on the freeway and it made a bunch of noise. Could this be a dead oil pump figured i would get your input before i start pulling stuff apart. Thx
Doesn't sound good. Try putting a wrench on the crank and try to turn the engine. If you lost oil pressure, you most likely spun a bearing. Then you would need to drop the oil pan and pull off the main and connecting rod caps to see what was damaged.
If you are lucky there may be no damage to the crank and journals. Then you can just put in new bearings, oil pump and hope the cam is OK.
I'm hoping thats not what happened figured i would ask before getting a new oil pump etc. and spending the money on it. Wife has it in her head that since when the light came on she pulled over right away and when the truck stoped it shut itself off is a good thing lol(had to tell her other wise).
I ran my D1 at fast idle one time when testing a used radiator I had just installed. Reached in the window, cranked it up, and immediately started looking for leaks under hood, coolant, oil, tranny fluid. They all go in one radiator. When I got through a few minutes later, and went to turn truck off, I notice oil light had never gone off. Duh! The oil cooler was 99% restricted, that is what took out the donor vehicle. It was two years ago. But I wasn't driving for miles as oil pressure dropped (you only know when light came on, could have been leaving a trail for many miles).
Might not be the pump, might be in the oil pan (pickup clogged, pickup came loose, etc.).
