Sponsored by: CARiD
Engine Troubles
Old Apr 9, 2008 | 01:59 PM
brunetto's Avatar
3rd Gear
Default Engine Troubles
I have a 2000 Discovery II with a 4.0 engine. The head gasket was leaking so the time came to replace it. I did so with no real problems accept two. 1. I broke the clip that holds the vacuum hose into the plenum from the brake booster. Any ideas where I might find a replacement, because with out it I have no brakes. 2. I now have no power. I mean no power. I can floor it for about 35 to 40 feet and I might hit 5mph. The idle is a little off but not bad and if it is in Park and I rev the engine it works and sounds fine. Any ideas what could be causing the issue.
Old Apr 9, 2008 | 02:25 PM
Bartell's Avatar
Default RE: Engine Troubles
ORIGINAL: brunetto
Interesting.
Brake boosters work by stealing some of the vaccum the engine creates to pull a membrane inside the booster when you step on the brakes. In doing so, they assist and multiply the effect of your foot on the hydraulic system. A clip holding a vacuum hose will not effect that.
On the other hand, badly installed head gaskets can, of course, effect the amount of compression and therefore vacuum the engine will produce. Your power will become some fraction of what it should be as will your vacuum. In extreme cases, you will barely be able to idle and you will have little or no braking power.
Can you do a compression test on each cylinder? Remove all the spark plugs, take off the big air conduit to the plenum nose and wedge the flap open with a screwdriver. Test one cylinder at a time. First dry and then again with one teaspoon of engine oil . Mark down your dry and wet findings for each cylinder.
BTW, did you use the old head bolts?
James
Old Apr 9, 2008 | 03:19 PM
Dealer only with no exceptions that I am aware of.
Old Apr 9, 2008 | 03:26 PM
brunetto's Avatar
3rd Gear
I did not reuse the headbolts. I am getting the tools to test the compresion to night. I will test and post the findings.
Old Apr 10, 2008 | 08:00 AM
brunetto's Avatar
3rd Gear
FIXED
All compression tests turned out fine. But when we pulled the plugs four of them looked like they had never fired. After further investigation we found that the plug on one side of the coil pack was bad. After replacing the plug all runs fine.
Old Apr 10, 2008 | 06:35 PM
Bartell's Avatar
ORIGINAL: brunetto
FIXED
Good man!
James
JessieM
Sep 20, 2012 10:22 PM
HanmerMang
Sep 8, 2012 12:46 PM
Sean 1313
Jan 13, 2006 06:25 AM
oberdahill
Sep 10, 2005 11:17 PM
Dave_Liverpool
Jun 22, 2005 11:29 AM
