Sponsored by: CARiD
Fan Motor Relay Keeps Blowing? Please HELP!
Old Mar 25, 2009 | 08:56 PM
BigDogg's Avatar
7th Gear
Question Fan Motor Relay Keeps Blowing? Please HELP!
I have a 1998 Range Rover 4.0. My Yellow relay for my Heater Blower motor (located in the fuse box under the hood) keeps blowing. When it blows there is a brown burn mark on one side of the relay. Also, the socket where this relay goes has the same brown burn mark on one side of the socket hole. Any help or advice is appreciated.
Thanks,
Dale
Email: WydellConley@aol.com
Old Mar 26, 2009 | 09:37 AM
You are going to burn up a wire harness, if you haven't already. Most likely the blower motor is locked up or shorted.
Let some one that knows the system check it ou and pull the relay and fuse in the mean time.
Old Mar 29, 2009 | 06:55 PM
roverMD's Avatar
make sure your pollen filters are not dirty and clogged up. it puts strain on the blower motor, causing high amp draw through the relay.
Old Apr 12, 2009 | 12:56 AM
oldrovertech's Avatar
you need a new fuse box dude. its a common issue..
Old Jul 4, 2012 | 08:49 AM
anc4's Avatar
Default hi
did you ever fix the problem, i have similar issue, right blower motor stopped, it was a fuse, changed fuse, motor worked then stopped, pulled motor and hot wired it and it worked, reinstalled motor, one relay not functionng, bought new relay, it melted within 1 day and the fuse blew, any ideas?
thanx
99 range rover 4.6 103k miles
Old Jul 4, 2012 | 09:24 AM
You just replied to a 3 year old thread!!!!!!!!!!!!!!!!!!!!!
DiscoRover007
Sep 2, 2014 04:49 PM
bosshogt
Feb 11, 2011 03:28 PM
rayrap
Dec 19, 2010 04:27 PM
wydell
Jun 11, 2009 12:40 AM
sfxgamer
Apr 19, 2009 01:06 AM
