Sponsored by: CARiD
Fixed the driver's seat buckle...still SRS light
Old Jun 19, 2011 | 06:10 AM
wheelgarage's Avatar
Default Fixed the driver's seat buckle...still SRS light
I was able to fix the buckle by opening the unit and pushing back the spring in place. Don't know who that can happen. I tested to see if the internal switch would activate when the seat belt is lock in the buckle. Few miles of driving, the SRS light is still on.
Right when we left the restaurant, the truck was dead. I rotated the key in the cylinder two times and allocate sudden, it started....? I got home and looked at the battery. The positive was loose. Fixed that, noticed the battery does not have the holddown bracket...great..
I guess it needs the light cleared????
Old Jun 19, 2011 | 07:42 AM
hilltoppersx's Avatar
put your truck info in your signature. do you have a d2? im guessing you had the code read and it said your seatbelt pre-tensioner was shot?
Old Jun 19, 2011 | 01:34 PM
Rovin4life's Avatar
actually alot of the pretensioner codes can go away by giving the harness under the seat a little room to move. Just release the connector from the frame and put a tie strap to keep it from getting caught and give it some room and it should go off.
Old Jun 19, 2011 | 08:23 PM
SRS light still on. Will have someone look at it when I am done trying to figure out the other issues with the cluster.
Signature updated...
Best4x4
Jul 4, 2015 05:02 PM
motorheadny
Jul 24, 2014 08:50 AM
Captjohn
Nov 2, 2012 01:49 PM
jigray3
Dec 3, 2011 09:26 PM
natihorny
Feb 24, 2010 04:51 AM
